OpenTX Integration
Revision as of 11:39, 5 April 2018 by Buell47 (Talk | contribs) (Created page with "'''Kürzere Zuleitung''' des Kabels |Empfänger")
Setup-Anleitung
für
Integration
Funktionen
◦ Einstellungen direkt im Sender
◦ Konfiguration des Geräts
◦ Kein Computer erforderlich
◦ Alles schnell erreichbar
Voraussetzungen
◦ OpenTX 2.2 mit Lua-Unterstützung
◦ Empfänger mit S.Port
◦ Integrationskabel für S.Port
1 Verkabelung
Um die Integration zu ermöglichen, müssen Sie Ihren Empfänger und Ihr Gerät nur nach folgendem Schema anschließen. Bitte beachten Sie, dass Sie dazu ein spezielles Kabel benötigen, das in unserem Shop erhältlich ist.
Kürzere Zuleitung des Kabels Empfänger - S.Port
Longer lead of the cable unit - SYS port
The integration cable is used for bi-­directional data transmission between unit and receiver, respectively transmitter. This include telemetry data and possibility to configure all parameters of the unit, directly from your transmitter.
It is completely separated from basic receiver part that is transmitting the channel data. Thus your existing connection with receiver can be untouched. It can work with PWM, PPM and S­Bus connection types.
Info.png For receiver that has a Molex connector for the S.Port (e.g. X4R, X4R­SB, XSR), please use provided connector and pins so that you can easily connect it to the servo connector.
Info.png S.Port connection alone will not work – it is used only for configuration. Channel data must be transmitted by a conventional protocols such as PWM, PPM or S­Bus.
Example 1: Connection scheme for the Integration part with X4R­SB receiver
Example 2: Optional adapter for X4R, X4R­SB, XSR receivers
2 Installation
Download script for Heli
FrSky Taranis X9D/X9D+/X9E: http://www.spirit-system.com/dl/opentx/Spirit-2.4.2-Taranis-x9.zip
FrSky Taranis Q X7: http://www.spirit-system.com/dl/opentx/Spirit-2.4.2-Taranis-x7.zip
FrSky Horus: http://www.spirit-system.com/dl/opentx/Spirit-2.4.2-Horus.zip
Download script for Aero
Then unzip the file and copy the „Spirit-­2.3.0“ (or „Spirit-Aero-1.2.0“ for Aero) directory to SD Card of your transmitter.
3 How to open the Menu
  2. Click the PAGE button.
  3. By clicking + and – buttons move to the „Spirit-2.3.0“ (or „Spirit-Aero-1.1.0“ for Aero) directory.
  4. Click the ENT button.
  3. By rotary manipulator move to the „Spirit-­2.3.0“ (or „Spirit-Aero-1.1.0“ for Aero) directory.
4 Integration Preview
FrSky Taranis integration:
FrSky Horus integration:
5 Troubleshooting
6 Telemetry data
  • Tmp1 [°C] - ESC Temperature
7 Usage
