YGE Telemetry
YGE LVT and YGE HVT ESCs have telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission the JST-Servo adapter is required. This cable is available in our Eshop.
It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Model |
Battery Voltage |
Battery Current |
Consumed Capacity |
ESC Temperature |
RPM |
| YGE 35LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 65LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 95LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 135LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 90HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 120HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 165HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
| YGE 205HVT | ✔ | ✔ | ✔ | ✔ | ✔ |
