Wiring
Revision as of 12:48, 7 September 2018 by Admin (Talk | contribs)
Spirit can be used as a standalone tail gyro or as a flybarless system. Wiring to the unit depends on the type of receiver used.
Warning.png Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
1 STANDALONE GYRO AND FLYBAR
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
μSpirit
CH1 – Pitch / Aileron servo
CH2 – Elevator servo
CH3 – Aileron / Pitch servo
CH4 – Rudder servo / Rudder ESC
CH4 – Rudder servo
Spirit Pro
CH4 – Rudder servo
Info.png Servos at positions CH1 and CH3 are dependent on the Swashplate settings. Aileron servo on the model is mostly positioned on the right side while pitch on the left side.
3 ESC/MOTOR WIRING
  2. In the Spirit unit - AUX (AUX1) port (Failsafe is handled by unit and/or additionally by receiver)
3.1 Castle ESC
  • Throttle Frequency: 60Hz.
3.2 Throttle Servo
3.3 µSpirit and Rudder ESC/Motor
4 CONNECTION OF STANDARD RECEIVER (PWM)
μSpirit – receiver type: PWM
Spirit Pro
5 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
Spirit Pro
5.1 Spektrum Multi Adapter
Wiring
Servo cable: RUD port
Orange wire: AIL pin
With this adapter it is possible to connect up to 4x Spektrum satellites with Spirit Pro. And up to 3x satellites with Spirit units.
6 CONNECTION OF FUTABA S-BUS RECEIVER
Spirit Pro
7 CONNECTION OF PPM RECEIVER
μSpirit – receiver type: PPM
8 CONNECTION OF JETI EX BUS RECEIVER
Info.png Connection to a BEC is optional. For models of 500 size and larger it is recommended to use dual power supply cables due to the increased power consumption. That means besides the EX Bus cable, an additional power supply cable should be connected to the AUX port.
9 CONNECTION OF SRXL/SUMD RECEIVER
10 CONNECTOR ORIENTATION
10.1 μSpirit
Warning.png Pin layout of the JST-ZH(R) connectors is different from standard Servo connectors. BROWN (Middle) wire is GND pin. ORANGE wire is SIGNAL pin. RED wire is +5V (BEC voltage). By using JST-Servo cables you can connect a classic Servos and all Spirit peripherals to the μSpirit even with Servo connectors.
10.2 Spirit and Spirit Pro
