Телеметрия Kontronik
Revision as of 10:14, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "Регуляторы Kontronik KOSMIK и JIVE PRO могут отдавать телеметрийные данные на соответствующем порту.")
Warning.png This telemetry is available only for Jeti integration (Jeti EX Bus), Spektrum integration and Futaba with the Spirit firmware v2.4+. In the future versions should work with other too.
1 Telemetry Cable
To allow the telemetry data transmission the Telem KONTRONIK cable is required. This cable is available in our Eshop.
2 Spirit Settings
First from all, power up the ESC and start the Spirit Settings as usually.
2.1 Telemetry activation
Set the ESC Telemetry in the Spirit Settings software.
Go to the Advanced/Telemetry settings and set the Kontronik KOSMIK & JIVE PRO option.
Then close the window and save the settings (CTRL+S). Now disconnect the battery.
3 Interfacing
At this step, connect the Telemetry cable according the following photo.
Info.png In this connection SYS port is used. Thus usage of this port for other purposes is limited when the Kontronik telemetry is enabled. Jeti Integration is still available for full configuration of the unit. If you need to use Spirit Settings software, you can deactivate temporarily ESC Telemetry by not turning transmitter on. At this moment normal connection for the USB interface or Wireless connection is established.
4 Displaying telemetry data
When previous steps were finished, you are ready to power up the battery.
After initialization you can display all telemetry data directly in your radio from now.
How to display the data is described in the integration guide:
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
JIVE PRO 80+ HV
JIVE PRO 120+ HV
KOSMIK 160 HV
COOL KOSMIK 160 HV
KOSMIK 200 HV
COOL KOSMIK 200+ HV
COOL KOSMIK 200 HV GOLD
