Телеметрия Kontronik
Revision as of 09:17, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "Необходимо выбрать тип телеметрии в настройках Spirit.")
Регуляторы Kontronik KOSMIK и JIVE PRO могут отдавать телеметрийные данные на соответствующем порту.
Warning.png Данная телеметрия доступна только для интеграции с Jeti (Jeti EX Bus), Spektrum интеграции и Futaba с прошивкой Spirit 2.4 и выше. В следующих версиях телеметрия станет доступной и для других интеграций.
1 Телеметрийный кабель
Для передачи телеметрийных данных необходим кабель Telem KONTRONIK , который можно приобрести в нашем магазине.
2 Spirit Settings
Для начала подключите регулятор и запустите программу настройки.
2.1 Включение телеметрии
Go to the Advanced/Telemetry settings and set the Kontronik KOSMIK & JIVE PRO option.
Then close the window and save the settings (CTRL+S). Now disconnect the battery.
3 Interfacing
At this step, connect the Telemetry cable according the following photo.
Info.png In this connection SYS port is used. Thus usage of this port for other purposes is limited when the Kontronik telemetry is enabled. Jeti Integration is still available for full configuration of the unit. If you need to use Spirit Settings software, you can deactivate temporarily ESC Telemetry by not turning transmitter on. At this moment normal connection for the USB interface or Wireless connection is established.
4 Displaying telemetry data
When previous steps were finished, you are ready to power up the battery.
After initialization you can display all telemetry data directly in your radio from now.
How to display the data is described in the integration guide:
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
JIVE PRO 80+ HV ✔ ✔ ✔ ✔ ✔ ✔
JIVE PRO 120+ HV ✔ ✔ ✔ ✔ ✔ ✔
KOSMIK 160 HV ✔ ✔ ✔ ✔ ✔ ✔
KOSMIK 200 HV ✔ ✔ ✔ ✔ ✔ ✔
