Телеметрия YGE
Revision as of 09:28, 15 October 2018 by Gstatopen (Talk | contribs) (Created page with "Модификация кабеля.")
Регуляторы YGE LVT и YGE HVT имеют функцию телеметрии доступную на кабеле для программирования. Данной функцией можно воспользоваться для получения данных. Необходимо обновить прошивку регуля до последней версии.
1 Телеметрийный кабель.
Для передачи телеметрийных данных необходим адаптер JST-Servo, который доступен в нашем магазине.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Модификация кабеля.
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
YGE 35LVT
YGE 65LVT
YGE 95LVT
YGE 135LVT
YGE 90HVT Opto
YGE 120HVT Opto
YGE 165HVT Opto
YGE 205HVT
