Cableado
Revision as of 11:29, 16 September 2016 by Admin (Talk | contribs) (Created page with "Spirit está preprogramado para 1520μs servo neutral impulso y la frecuencia de 50Hz - por favor asegúrese de tener los parámetros servo correctos seleccionados según lo e...")
Spirit puede ser utilizado como un giro de cola independiente o como un sistema flybarless. Cableado de la unidad depende del tipo de receptor utilizado.
NOTA
Spirit está preprogramado para 1520μs servo neutral impulso y la frecuencia de 50Hz - por favor asegúrese de tener los parámetros servo correctos seleccionados según lo especificado por el fabricante del servo. If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
1 STANDALONE GYRO AND FLYBAR
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
CH1 – Pitch / Aileron servo
CH2 – Elevator servo
CH3 – Aileron / Pitch servo
CH4 – Rudder servo
Spirit Pro
CH4 – Rudder servo
Spirit – receiver type: PWM
Spirit Pro
Spirit Pro
Spirit Pro
6 CONNECTION OF PPM RECEIVER
Spirit – receiver type: PPM
9 CONNECTOR ORIENTATION
