TelMe Telemetry
Kontronik ESCs are utilizing special 5-pin port connector for telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC to at least 1.13 firmware version. Older versions do not support TelMe protocol.
1 Telemetry Cable
To allow the telemetry data transmission the Telem KONTRONIK v2 cable is required. This cable is available in our Eshop.
We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit.
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
5-pin JST connector of the Telem KONTRONIK v2 cable should be connected to the ESC. In case of Kontronik KOSMIK you can select any free port.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik TelMe option.
4 Displaying telemetry data
5 Supported models
Model |
Battery Voltage |
Battery Current |
BEC Voltage |
Consumed Capacity |
ESC Temperature |
RPM |
KOLIBRI 140 LV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
JIVE PRO 80+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
JIVE PRO 120+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
KOSMIK 160 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 160 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
KOSMIK 200 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 200+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 200 HV GOLD | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
