Spektrum Integration
From version 2.4.3 you can use the Spektrum integration!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
[hide]1 Requirements
- Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20 or IX12
- Serial Telemetry receiver: SPM4649T.
- Jeti Integration cable available in our stores (or own modification of the wires).
- Spirit firmware: 2.4.3 (with the new Bootloader flashed - see the Troubleshooting section)
2 Wiring
2.1 SPM4649T receiver
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be bound normally as described in the Manual.
SPM4649T receiver Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding. Spirit unit Other end of the Jeti integration cable should be connected so that Orange wire is in the AIL pin. Powering plug with Red and Brown wires in the RUD port. (see the photo)
- Spirit Pro - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit - 1x SPM4649T + 0-1x Spektrum satellites
- µSpirit - 1x SPM4649T + 0-1x Spektrum satellites
In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
3.2 Configuration
Configure:
- 1: ESC
- 2: Text Gen
- 3: Flight Pack mAh
5 Integration Menu
To navigate in the menu you can use Aileron and Elevator sticks.
6 Telemetry data
6.1 Displaying the data
- Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
7 Troubleshooting
