Wiring
Spirit can be used as a standalone tail gyro or as a flybarless system. Wiring to the unit depends on the type of receiver used.
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
- 1 STANDALONE GYRO AND FLYBAR
- 2 FLYBARLESS
- 3 SERVO CONNECTION
- 4 ESC/MOTOR WIRING
- 5 CONNECTION OF STANDARD RECEIVER (PWM)
- 6 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
- 7 CONNECTION OF FUTABA S-BUS RECEIVER
- 8 CONNECTION OF PPM RECEIVER
- 9 CONNECTION OF JETI EX BUS RECEIVER
- 10 CONNECTION OF SRXL/SUMD RECEIVER
- 11 CONNECTOR ORIENTATION
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
3 SERVO CONNECTION
Spirit units have full support for all types of servos. By default unit is pre-configured for 1520us pulse and 50Hz frequency. This will ensure your servos can't be damaged. For the initial configuration we recommend to proceed according the Setup Wizard instructions. There you will see how to connect each servo individually.
If you are unsure do not connect any servo yet. Please use the Setup Wizard in Spirit Settings software to show how to connect the servos properly.
| μSpirit |
| CH1 – Pitch / Aileron servo |
| CH2 – Elevator servo |
| CH3 – Aileron / Pitch servo |
| CH4 – Rudder servo / Rudder ESC |
| Spirit |
| CH4 – Rudder servo |
| Spirit Pro |
| CH0 – auxiliary (optional) cyclic servo for CCPM 90 swashplate type. |
4 ESC/MOTOR WIRING
With Spektrum DSM2/X satellites throttle must be connected always to the unit.
4.1 Castle ESC
- Throttle Frequency: 60Hz.
4.2 Throttle Servo
4.3 µSpirit and Rudder ESC/Motor
μSpirit – receiver type: PWM
Spirit 2– receiver type: PWM
Spirit Pro, Spirit 2
6.1 Spektrum Multi Adapter
Servo cable: RUD port
Orange wire: AIL pin
μSpirit, Spirit Pro, Spirit 2
μSpirit – receiver type: PPM
Spirit 2 – receiver type: PPM
11.1 μSpirit
11.2 Spirit and Spirit Pro
11.3 Spirit 2
