Wiring
[hide]- 1 STANDALONE GYRO AND FLYBAR
- 2 FLYBARLESS
- 3 CONNECTOR ORIENTATION
- 4 SERVOS WIRING
- 5 ESC/MOTOR WIRING
- 6 CONNECTION OF STANDARD RECEIVER (PWM)
- 7 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
- 8 CONNECTION OF FUTABA S-BUS RECEIVER
- 9 CONNECTION OF PPM RECEIVER
- 10 CONNECTION OF JETI EX BUS RECEIVER
- 11 CONNECTION OF SRXL/SUMD RECEIVER
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
Before plugging-in any connector to the Spirit unit please check carefully following instructions. See how to connect all cables in the right orientation with respect to Spirit unit you have.
3.1 μSpirit
3.2 Spirit and Spirit Pro
3.3 Spirit 2
4 SERVOS WIRING
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
μSpirit |
CH1 – Pitch / Aileron servo |
CH2 – Elevator servo |
CH3 – Aileron / Pitch servo |
CH4 – Rudder servo / Rudder ESC |
Spirit, Spirit 2 |
CH4 – Rudder servo |
Spirit Pro |
CH0 – auxiliary (optional) cyclic servo for CCPM 90 swashplate type. |
5 ESC/MOTOR WIRING
With Spektrum DSM2/X satellites throttle must be connected always to the unit.
5.1 Castle ESC
- Throttle Frequency: 60Hz.
5.2 Throttle Servo
μSpirit – receiver type: PWM
Spirit 2– receiver type: PWM
Spirit Pro, Spirit 2
7.1 Spektrum Multi Adapter
Servo cable: RUD port
Orange wire: AIL pin
μSpirit, Spirit Pro, Spirit 2
μSpirit – receiver type: PPM
Spirit 2 – receiver type: PPM
