Spektrum SRXL2
Revision as of 09:06, 7 February 2020 by Admin (Talk | contribs) (Created page with "<translate><!--T:10--> SRXL2 is new telemetry enabled receiver technology from Spektrum that is able to carry all channel data and telemetry at the same time. This mean that y...")
SRXL2 is new telemetry enabled receiver technology from Spektrum that is able to carry all channel data and telemetry at the same time. This mean that you will not need to connect anything else except one cable.
By using the SRXL2 adapter you will not need any additional modification to the receiver. Cable is available in our E-Shop.
Info.png In case that your SRXL2 receiver is not bound yet, you can do so by a Bind plug. Press the Bind button at the receiver during power. Manual.
SRXL2 receiver Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding.
SRXL2 receiver Spirit Pro unit
1 Spirit Settings
2 Radio Integration
If you want to use Integration and Telemetry features please continue with Spektrum Integration page.
