Spektrum Integráció
A 2.4.3 verziótól használható a Spektrum Integráció!
Ez azt jelenti, hogy a Spirit egységeket valós időben teljes mértékben konfigurálhatja a Spektrum adóval, számítógép nélkül.
1 Követelmények
A működéshez szüksége lesz:
- Spektrum adó: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20
- Soros telemetriai vevő: SPM4649T.
- Jeti integrációs kábel megrendelhető a boltunkban (vagy módosíthatja saját kezűleg a vezetéket).
- Spirit firmware: 2.4.3 (az új Bootloader villogásával lásd a Troubleshooting Hibaelhárítás részt)
2 Bekötés
2.1 SPM4649T receiver
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be bound normally as described in the Manual.
SPM4649T receiver Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding. Spirit unit Other end of the Jeti integration cable should be connected so that Orange wire is in the AIL pin. Powering plug with Red and Brown wires in the RUD port. (see the photo)
- Spirit 2 - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit Pro - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit - 1x SPM4649T + 0-1x Spektrum satellites
- µSpirit - 1x SPM4649T + 0-1x Spektrum satellites
In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
3.2 Configuration
Configure:
- 1: ESC
- 2: Text Gen
- 3: Flight Pack mAh
5 Integration Menu
To navigate in the menu you can use Aileron and Elevator sticks.
6 Telemetry data
6.1 Displaying the data
- Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
7 Troubleshooting
