OpenTX Integráció
Revision as of 12:08, 24 August 2020 by PSzakra (Talk | contribs) (Created page with "OpenTX Integráció")
Setup guide
for
Integration
Features
◦ Settings directly in the transmitter
◦ Configuration of the unit
◦ No need for computer
◦ Everything quickly accessible
Requirements
◦ OpenTX 2.2 with Lua support
◦ Receiver with S.Port
◦ Integration cable for S.Port
1 Wiring
To enable the Integration, you have to only connect your receiver and unit according to the following scheme. Please note, that to make this possible, you will need special cable that is available in our eshop.
So you will need to connect:
  • FrSky Integration cable
Shorter lead of the cable receiver - S.Port
Longer lead of the cable unit - SYS port
The integration cable is used for bi-­directional data transmission between unit and receiver, respectively transmitter. This include telemetry data and possibility to configure all parameters of the unit, directly from your transmitter.
It is completely separated from basic receiver part that is transmitting the channel data. Thus your existing connection with receiver can be untouched. It can work with PWM, PPM and S­Bus connection types.
Info.png For receiver that has a Molex connector for the S.Port (e.g. X4R, X4R­SB, XSR), please use provided connector and pins so that you can easily connect it to the servo connector.
Info.png S.Port connection alone will not work – it is used only for configuration. Channel data must be transmitted by a conventional protocols such as PWM, PPM or S­Bus.
Example 1: Connection scheme for the Integration part with X4R­SB receiver
Example 2: Optional adapter for X4R, X4R­SB, XSR receivers
2 Installation
Download script for Heli
All FrSky Taranis and Horus radios - ENGLISH: http://www.spirit-system.com/dl/opentx/Spirit-2.7.0-en.zip
All FrSky Taranis and Horus radios - ČESKY: http://www.spirit-system.com/dl/opentx/Spirit-2.7.0-cs.zip
Download script for Aero
Then unzip the file and copy the „Spirit-­2.6.0“ (or „Spirit-Aero-1.3.0“ for Aero) directory to SD Card of your transmitter.
3 How to open the Menu
  2. Click the PAGE button.
  3. By clicking + and – buttons move to the „Spirit-2.3.0“ (or „Spirit-Aero-1.1.0“ for Aero) directory.
  4. Click the ENT button.
  3. By rotary manipulator move to the „Spirit-­2.3.0“ (or „Spirit-Aero-1.1.0“ for Aero) directory.
4 Integration Preview
FrSky Taranis integration:
FrSky Horus integration:
5 Troubleshooting
6 Telemetry data
  • Tmp1 [°C] - ESC Temperature
7 Usage
