Futaba Telemtria
Revision as of 21:55, 1 September 2020 by PSzakra (Talk | contribs) (Created page with "FASSTest vevő: '''R7003SB, R7006SB, R7008SB, R7014SB vagy R7018SB'''.")
čeština • ‎Deutsch • ‎English • ‎français • ‎magyar • ‎italiano • ‎русский • ‎中文(繁體)‎
A 2.4.3 verziótól használhatja a Futaba Telemetria teljes támogatását!
Ez azt jelenti, hogy ön láthatja a Spirit által elküldött összes telemetriai változót S.BUS2-vel (FASSTest vevő esetén) valós időben.
1 Követelmények
Ahhoz, hogy működjön szükséges:
  • Futaba adó: 14SG, 16SZ, 18MZ or 18SZ
  • FASSTest vevő: R7003SB, R7006SB, R7008SB, R7014SB vagy R7018SB.
  • FrSky Integration cable available in our stores (with a small modification).
  • Futaba firmware: Latest.
  • Spirit firmware: 2.4.3.
2 Cable modification
To allow telemetry transmission the FrSky Integration cable must be modified. For this purpose you will need a servo' plastic plug (already included with the cable).
Modification of the longer end
  1. Use a needle to free-up the Red wire from the plastic.
  2. Then plug the Red wire from the middle to a separate servo plastic (at the signal position).
Resulting cable modification
3 Wiring
The FrSky Integration cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
Longer lead of the cable unit - RUD and ELE/PIT/AIL (see the photo)
Shorter lead of the cable receiver - S.BUS2
Warning.png The FrSky Integration cable is not able to carry power to the receiver. For this purpose you will need to add a normal servo cable between receiver and unit to a free port (for example AUX, AUX2 or CH0 port connected with 8/SB). Alternatively you can use one additional wire and connect it to the middle pin of the RUD that is not connected. You can also use a secondary BEC output so no other cable is required.
Info.png Make sure that the receiver is bound in the FASSTest mode, otherwise telemetry will not work.
Info.png Spirit: If S-BUS Adapter is used with Spirit, then it will be replaced by the FrSky Integration cable.
Info.png Spirit Pro & uSpirit: Servo cable that was used for connection between receiver and unit will be replaced by the FrSky Integration cable.
4 Transmitter preparation
4.1 Configuration
  1. Power up the transmitter and from the Main screen go to the LINKAGE MENU (LNK button) and then to the SENSOR page.
  2. For the 8th position Slot select KONTRONIK as the Sensor. This will overwrite automatically next 6 slots.
5 Telemetry data
  • Rx-BATT [V] - BEC Voltage (provided by the receiver)
  • EXT-VOLT [V] - Voltage measured on external wires (optionally connected to the receiver)
  • CURRENT [A] - ESC Telemetry | Main Battery current
  • VOLTAGE [V] - ESC Telemetry | Main Battery voltage
  • DISCHARG [mAh] - ESC Telemetry | Main Battery consumed capacity
  • TEMP [°C] - ESC Telemetry | FET temperature of the ESC
  • PWM [%] - ESC Telemetry | Throttle percentage (provided by unit)
  • BEC CURRENT [%] - Vibration level (0 - 10% is normal level, 1A = 1%, provided by unit)
