Castle Telemtria
Revision as of 21:32, 1 September 2020 by PSzakra (Talk | contribs) (Created page with "ESC konfiguráció")
Castle Creations ESC has feature called Link Live. This allows bi-directional data transmission over the Throttle cable. To allow the ESC telemetry, it is necessary to enable this feature first. It is disabled by default. Once enabled, it is required that a device which is sending Throttle data (Spirit unit) has enabled support for this tranmission too. In other case Throttle signal will be ignored.
1 ESC konfiguráció
With usage of the Castle Link interface, please start the Castle Link software to open the configuration settings of your ESC. There you have to enable Link-Live feature.
2 Telemetry Cable
To allow the telemetry data transmission Telem CC cable is required. This cable is available in our Eshop.
For Experts: Alternatively you can modify your current Throttle cable by adding 10kOhm resistor between white (signal) and red (+) wires. In this case the Telemetry cable is not required.
3 Interfacing
Connect the Telemetry cable to the AUX(1) port in the unit, where you normally connect the Throttle cable of the ESC. Connect the Throttle cable to the end of the Telem CC cable.
4.1 Throttle Assignment
Once cable is connected, it is absolutely necessary to assign the Throttle (if not assigned yet).
Go to the General/Channels and assign a channel to the Throttle.
4.2 Telemetry activation
Go to the Advanced/Telemetry settings and set the Castle Creations Phoenix & Talon option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
Phoenix Edge 50
Phoenix Edge 75
Phoenix Edge 100
Phoenix Edge 130
Phoenix Edge HV 40
Phoenix Edge HV 80
Phoenix Edge HV 120
Phoenix Edge HV 160
Phoenix Edge HVF 160
Phoenix Edge Lite 50
Phoenix Edge Lite 75
Phoenix Edge Lite 100
Phoenix Edge Lite 130
Phoenix Edge Lite HV 40
Phoenix Edge Lite HV 80
Phoenix Edge Lite HV 120
Phoenix Edge Lite HV 160
Phoenix Talon 15 x x
Phoenix Talon 25 x x
Phoenix Talon 35 x x
Phoenix Talon 90 x x
Phoenix Talon HV 120 x x
