Kontronik Telemetria
Revision as of 22:42, 1 September 2020 by PSzakra (Talk | contribs)
Kontronik KOSMIK és a JIVE PRO ESC beépített telemetriás funkcióval rendelkezik a Programozási portban. Ez lehetővé teszi a telemetriai adatok továbbítását az egységbe.
Warning.png Ez a telemetria csak a JETI integrációban (Jeti EX Bus9), a Spektrum integráció és a Futaba-nál érhető el a Spirit 2.4.+-s verziótól. A későbbi verziókkal is működik.
1 Telemetria Vezeték
A telemetriai adatok továbbításához a Telem KONTRONIK kábel szükséges. Ez a kábel elérhető az Eshop.-ban.
2 Spirit Settings
First from all, power up the ESC and start the Spirit Settings as usually.
2.1 Telemetry activation
Set the ESC Telemetry in the Spirit Settings software.
Go to the Advanced/Telemetry settings and set the Kontronik KOSMIK & JIVE PRO option.
Then close the window and save the settings (CTRL+S). Now disconnect the battery.
3 Interfacing
At this step, connect the Telemetry cable according the following photo.
Info.png In this connection SYS port is used. Thus usage of this port for other purposes is limited when the Kontronik telemetry is enabled. Jeti Integration is still available for full configuration of the unit. If you need to use Spirit Settings software, you can deactivate temporarily ESC Telemetry by not turning transmitter on. At this moment normal connection for the USB interface or Wireless connection is established.
4 Displaying telemetry data
When previous steps were finished, you are ready to power up the battery.
After initialization you can display all telemetry data directly in your radio from now.
How to display the data is described in the integration guide:
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
JIVE PRO 80+ HV ✔ ✔ ✔ ✔ ✔ ✔
JIVE PRO 120+ HV ✔ ✔ ✔ ✔ ✔ ✔
KOSMIK 160 HV ✔ ✔ ✔ ✔ ✔ ✔
KOSMIK 200 HV ✔ ✔ ✔ ✔ ✔ ✔
