Zapojení
Systém Spirit lze zapojit jako samostatné gyro vrtulky či bezpádlový systém. Zapojení jednotky se odvíjí také od typu přijímače.
POZOR
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
1 STANDALONE GYRO AND FLYBAR
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
Spirit |
CH1 – Pitch / Aileron servo |
CH2 – Elevator servo |
CH3 – Aileron / Pitch servo |
CH4 – Rudder servo |
Spirit Pro |
CH0 – auxiliary (optional) cyclic servo for CCPM 90 swashplate type. |
Servos at positions CH1 and CH3 are dependent on the Swashplate settings.
Aileron servo on the model is mostly positioned on the right side while pitch on the left side.
Spirit – receiver type: PWM
6 CONNECTION OF PPM RECEIVER
Spirit – receiver type: PPM
9 CONNECTOR ORIENTATION
