Preparación del SpiritRS
Revision as of 15:51, 12 October 2020 by Luisgarag (Talk | contribs) (Created page with "Spirit System ofrece la emisora DS-12, hecha a medida para el Spirit RS. Esto significa que podrá utilizar todo su potencial sin necesidad de adquirir módulos de software ad...")
Para operar el Spirit RS puede utilizar cualquier emisora JETI DUPLEX.
Las emisoras compatibles son:
  • DC-14
  • DC-16
  • DC-16 II
  • DC-24
  • DS-12
  • DS-14
  • DS-16
  • DS-24
Recomendamos comenzar con un perfil de modelo ya que necesitará realizar solo unos pequeños cambios.
Spirit System ofrece la emisora DS-12, hecha a medida para el Spirit RS. Esto significa que podrá utilizar todo su potencial sin necesidad de adquirir módulos de software adicionales.
1 Beginning
2 Turning On and Off
3 New Profile
In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.04 is required for this option - only available in DS-12 Spirit Edition at the moment).
4 Basic Helicopter settings
4.1 Flight Modes
Info.png Non-Spirit Jeti radio might need to get extension module for Flight modes (from swshop.jetimodel.com). Alternatively you can use only 3 Flight modes.
Info.png Instead of Autorot. flight mode you can set Throttle Cut switch.
4.2 Throttle Curve
4.3 Pitch Curve
4.4 Gyro Gain
For the beginning you can use these values. Positive value will activate Head-Lock Gyro mode, while a negative value will engage Normal (Rate) mode.
For further Gyro Gain tuning you can set 50, 60, 70% gains or assign a potentiometer.
