Telemetría SpiritRS
Revision as of 16:17, 17 October 2020 by Luisgarag (Talk | contribs) (Created page with "Puerto E1")
El Spirit RS cuenta con dos entradas independientes para sensores JETI. Estos sensores son compatibles con SpiritRS y se usa de la misma manera que con la línea de receptores REX.
Se necesitase montar más sensores, puede utilizar el JETI model EXPANDER. De esta manera podrá conectar hasta 8 sensores al mismo puerto.
Puertos de telemetría disponibles:
  • E1
  • EXT
Por defecto ambos se encuentran configurados como JETIBOX/Sensor, lo que significa que no tiene que hacer ningún ajuste, únicamente conectar sus sensores.
1 Cableado de los Sensores de Telemetría
1.1 Puerto E1
Connect Sensor or Expander cable directly without any change.
1.2 EXT port
Connect Sensor or Expander cable in so that RED/BROWN wires are at the AUX port (or any other free powering port) and ORANGE wire at the EXT pin. In case of lack of free ports, please use an Y-cable.
Info.png Original connector must be modified so that two servo connectors are used. You can use JETI integration cable for this purpose.
2 Telemetry Sensor Data
You can set display Sensor Data at the Main screen in the Displayed Telemetry menu.
3 Spirit Telemetry
Besides JETI model sensors you can also utilize the ESC Telemetry and Spirit telemetry variables.
So that you can interface your ESC and display telemetry data such as Battery Voltage, Current, Consumed Capacity, Temperature, RPM.
3.1 List of supported ESCs
