Cablaggio
Revision as of 15:36, 12 January 2021 by DaniloB (Talk | contribs) (Created page with "Spirit può essere utilizzato come giroscopio di coda autonomo o come sistema senza flybar o come unità di stabilizzazione flybar.")
1 STANDALONE GYRO AND FLYBAR
2 FLYBARLESS
3 CONNECTOR ORIENTATION
Before plugging-in any connector to the Spirit unit please check carefully following instructions. See how to connect all cables in the right orientation with respect to Spirit unit you have.
3.1 μSpirit
Warning.png Pin layout of the JST-ZH(R) connectors is different from standard Servo connectors. BROWN (Middle) wire is GND pin. ORANGE wire is SIGNAL pin. RED wire is +5V (BEC voltage). By using JST-Servo cables you can connect a classic Servos and all Spirit peripherals to the μSpirit even with Servo connectors.
3.2 Spirit and Spirit Pro
3.3 Spirit 2
4 SERVOS WIRING
Warning.png Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
μSpirit
CH1 – Pitch / Aileron servo
CH2 – Elevator servo
CH3 – Aileron / Pitch servo
CH4 – Rudder servo / Rudder ESC
Spirit, Spirit 2
CH4 – Rudder servo
Spirit Pro
CH4 – Rudder servo
Info.png Servos at positions CH1 and CH3 are dependent on the Swashplate settings. Aileron servo on the model is mostly positioned on the right side while pitch on the left side.
5 ESC/MOTOR WIRING
  2. In the Spirit unit - AUX (AUX1) port (Failsafe is handled by unit and/or additionally by receiver)
5.1 Castle ESC
  • Throttle Frequency: 60Hz.
5.2 Throttle Servo
6 CONNECTION OF STANDARD RECEIVER (PWM)
μSpirit – receiver type: PWM
Spirit 2– receiver type: PWM
Spirit Pro, Spirit 2
7 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
7.1 Spektrum Multi Adapter
Wiring
Servo cable: RUD port
Orange wire: AIL pin
8 CONNECTION OF FUTABA S-BUS RECEIVER
μSpirit, Spirit Pro, Spirit 2
9 CONNECTION OF PPM RECEIVER
μSpirit – receiver type: PPM
Spirit 2 – receiver type: PPM
10 CONNECTION OF JETI EX BUS RECEIVER
Info.png Connection to a BEC is optional. For models of 500 size and larger it is recommended to use dual power supply cables due to the increased power consumption. That means besides the EX Bus cable, an additional power supply cable should be connected to the AUX port.
11 CONNECTION OF SRXL/SUMD RECEIVER
