SpiritRS Preparazione
Revision as of 14:16, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "Inizio")
Per azionare l'unità Spirit RS è possibile utilizzare qualsiasi radio JETI DUPLEX.
Le radio supportate sono:
  • DC-14
  • DC-16
  • DC-16 II
  • DC-24
  • DS-12
  • DS-14
  • DS-16
  • DS-24
Ti consigliamo di iniziare con un profilo del modello chiaro poiché avrai bisogno solo di poche modifiche.
Spirit System offre radio DS-12 su misura per Spirit RS. Ciò significa che sarai in grado di utilizzare completamente tutte le funzionalità fuori dagli schemi.
1 Inizio
2 Turning On and Off
3 New Profile
In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.04 is required for this option - only available in DS-12 Spirit Edition at the moment).
4 Basic Helicopter settings
4.1 Flight Modes
Info.png Non-Spirit Jeti radio might need to get extension module for Flight modes (from swshop.jetimodel.com). Alternatively you can use only 3 Flight modes.
Info.png Instead of Autorot. flight mode you can set Throttle Cut switch.
4.2 Throttle Curve
4.3 Pitch Curve
4.4 Gyro Gain
For the beginning you can use these values. Positive value will activate Head-Lock Gyro mode, while a negative value will engage Normal (Rate) mode.
For further Gyro Gain tuning you can set 50, 60, 70% gains or assign a potentiometer.
