Castle Telemetria
Revision as of 15:08, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "Castle Telemetria")
Castle Creations ESC has feature called Link Live. This allows bi-directional data transmission over the Throttle cable. To allow the ESC telemetry, it is necessary to enable this feature first. It is disabled by default. Once enabled, it is required that a device which is sending Throttle data (Spirit unit) has enabled support for this tranmission too. In other case Throttle signal will be ignored.
1 ESC configuration
With usage of the Castle Link interface, please start the Castle Link software to open the configuration settings of your ESC. There you have to enable Link-Live feature.
2 Telemetry Cable
To allow the telemetry data transmission Telem CC cable is required. This cable is available in our Eshop.
For Experts: Alternatively you can modify your current Throttle cable by adding 10kOhm resistor between white (signal) and red (+) wires. In this case the Telemetry cable is not required.
3 Interfacing
Connect the Telemetry cable to the AUX(1) port in the unit, where you normally connect the Throttle cable of the ESC. Connect the Throttle cable to the end of the Telem CC cable.
4.1 Throttle Assignment
Once cable is connected, it is absolutely necessary to assign the Throttle (if not assigned yet).
Go to the General/Channels and assign a channel to the Throttle.
4.2 Telemetry activation
Go to the Advanced/Telemetry settings and set the Castle Creations Phoenix & Talon option.
5 Displaying telemetry data
6 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
Phoenix Edge 50 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge 75 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge 100 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge 130 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge HV 40 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge HV 80 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge HV 120 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge HV 160 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge HVF 160 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite 50 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite 75 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite 100 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite 130 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite HV 40 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite HV 80 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite HV 120 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Edge Lite HV 160 ✔ ✔ ✔ ✔ ✔ ✔
Phoenix Talon 15 ✔ x ✔ x ✔ ✔
Phoenix Talon 25 ✔ x ✔ x ✔ ✔
Phoenix Talon 35 ✔ x ✔ x ✔ ✔
Phoenix Talon 90 ✔ x ✔ x ✔ ✔
Phoenix Talon HV 120 ✔ x ✔ x ✔ ✔
