Spektrum Integrazione
Revision as of 17:44, 13 January 2021 by DaniloB (Talk | contribs) (Created page with "con il nuovo Bootloader lampeggiante - vedere la sezione Risoluzione dei problemi")
Dalla versione 2.4.3 è possibile utilizzare l'integrazione Spektrum!
Ciò significa che puoi configurare completamente le unità Spirit con i trasmettitori Spektrum in tempo reale senza bisogno di un computer.
1 Requisiti
  • Trasmettitore Spektrum: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ, DX20, IX12, IX20
  • Ricevitore telemetria seriale: SPM4649T.
  • Cavo di integrazione Jeti disponibile nei nostri negozi (o modifica propria dei fili).
  • Spirit firmware: 2.4.3 (con il nuovo Bootloader lampeggiante - vedere la sezione Risoluzione dei problemi)
2 Wiring
2.1 SPM4649T receiver
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
Info.png In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be bound normally as described in the Manual.
  • Spirit 2 - 1x SPM4649T + 0-2x Spektrum satellites
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
  • 3: Flight Pack mAh
5 Integration Menu
5.1 Entering the menu
5.2 Closing the menu
5.3 Navigation
Info.png To navigate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
6 Telemetry data
6.1 Displaying the data
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
7 Troubleshooting
