Flashing Fallito
Revision as of 14:36, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "La domanda importante è: perché ha fallito ?")
1 L'unità non funziona dopo flashing
Nel caso in cui l'unità non funzioni correttamente dopo il processo di flashing, è possibile utilizzare la seguente guida per farlo funzionare di nuovo.
Possibilities are:
  • Connection between unit and computer is not stable (check the cables).
  • Bad USB interface driver in your Operating System.
If you are on Windows, please re-install the software with the option for Driver installation. Then it will install correct driver. Then reboot the PC.
If you are on Mac, use this driver: OSX 11.0 Big Sur
Other drivers will very probably not work correctly - especially for the flashing process!
Requirements for the Recovery process:
  1. Correct driver in your operating system.
  2. Status LED of the unit must be pulsating after power up.
2 How to revive the unit
  1. Connect the USB interface to your PC and the unit (SYS port).
  2. Start the software. Select Recovery mode when prompted.
  3. Go to the Update tab and select firmware you want to flash (4df file extension).
  4. Power up the unit (from your BEC or a battery). Status LED should pulsate.
  5. Press the Flash button - Flashing process should start immediately.
  6. In 10 seconds, unit should be operating again without any issue. Your settings are untouched.
