Flashing Fallito
Revision as of 14:38, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "La connessione tra l'unità e il computer non è stabile (controllare i cavi).")
1 L'unità non funziona dopo flashing
Nel caso in cui l'unità non funzioni correttamente dopo il processo di flashing, è possibile utilizzare la seguente guida per farlo funzionare di nuovo.
La domanda importante è: perché ha fallito ?
- Le possibilità sono:
- La connessione tra l'unità e il computer non è stabile (controllare i cavi).
- Bad USB interface driver in your Operating System.
If you are on Windows, please re-install the software with the option for Driver installation. Then it will install correct driver. Then reboot the PC.
If you are on Mac, use this driver: OSX 11.0 Big Sur
Other drivers will very probably not work correctly - especially for the flashing process!
- Requirements for the Recovery process:
- Correct driver in your operating system.
- Status LED of the unit must be pulsating after power up.
2 How to revive the unit
- Connect the USB interface to your PC and the unit (SYS port).
- Start the software. Select Recovery mode when prompted.
- Go to the Update tab and select firmware you want to flash (4df file extension).
- Power up the unit (from your BEC or a battery). Status LED should pulsate.
- Press the Flash button - Flashing process should start immediately.
- In 10 seconds, unit should be operating again without any issue. Your settings are untouched.
