Wiring
[hide]- 1 STANDALONE GYRO AND FLYBAR
- 2 FLYBARLESS
- 3 CONNECTOR ORIENTATION
- 4 SERVOS WIRING
- 5 ESC/MOTOR WIRING
- 6 CONNECTION OF STANDARD RECEIVER (PWM)
- 7 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
- 8 CONNECTION OF FUTABA S-BUS RECEIVER
- 9 CONNECTION OF PPM RECEIVER
- 10 CONNECTION OF JETI EX BUS RECEIVER
- 11 CONNECTION OF SRXL/SUMD RECEIVER
- 12 CONNECTION OF FRSKY F.PORT RECEIVER
2 FLYBARLESS
Before plugging-in any connector to the Spirit unit please check carefully following instructions. See how to connect all cables in the right orientation with respect to Spirit unit you have.
3.1 μSpirit
3.2 Spirit and Spirit Pro
4 SERVOS WIRING
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
μSpirit |
CH1 – Pitch / Aileron servo |
CH2 – Elevator servo |
CH3 – Aileron / Pitch servo |
CH4 – Rudder servo / Rudder ESC |
Spirit, Spirit 2, Spirit RS |
CH4 – Rudder servo |
Spirit Pro, Spirit GT, Spirit GTR |
CH0 – auxiliary (optional) cyclic servo for CCPM 90 swashplate type. |
5 ESC/MOTOR WIRING
With Spektrum DSM2/X satellites throttle must be connected always to the unit.
5.1 Castle ESC
- Throttle Frequency: 60Hz.
5.2 Throttle Servo
μSpirit – receiver type: PWM
Spirit 2– receiver type: PWM
Spirit GT– receiver type: PWM
Spirit 2, Spirit Pro, Spirit GT
Spirit Pro, Spirit 2, Spirit GT
7.1 Spektrum Multi Adapter
Servo cable: RUD port
Orange wire: AIL pin
μSpirit, Spirit Pro, Spirit 2, Spirit GT
μSpirit – receiver type: PPM
Spirit 2 – receiver type: PPM
Spirit GT– receiver type: PPM
Connection to a BEC is optional. For models of 500 size and larger it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port. This protocol is supported by the most FrSky ACCST receivers. Presently F.PORT 1 generation is fully supported. It allows to carry channel, telemetry and integration data at the same time. Only Spirit GT units have support for this protocol. More details can be found at the FrSky FPort page
