Jeti Integration
Revision as of 09:21, 12 July 2021 by Admin (Talk | contribs)
From version 1.1.0 you can use the JETI integration! This mean you can fully configure Spirit units with JETI transmitters in real-time without need of a computer.
1 Requirements
  • Jeti Duplex transmitter: DC/DS 12, 14, 16 or 24
  • Jeti Duplex receiver with a free EX port.
  • Jeti Integration cable available in our stores (not for Spirit RS, Spirit GT, Spirit GTR).
  • Configuration file for the transmitter.
2 Wiring
The Jeti cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • For new REX receivers the port label is E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
  • To buy a REX receiver where you can use a telemetry sensors and the Jeti integration together.
3 Transmitter preparation
Now download the Configuration file, which has ZIP extension. The file archive must be extracted first (by Right click). You will obtain SPIRIT-3-3 folder. Content of this folder must be copied to the Devices directory at the SD-Card of your transmitter. Without this you will see an error message when the Spirit device is opened.
This mean Devices directory will contain SPIRIT.bin file and SPIRIT directory with images inside.
It is very important to use the same version of the BIN file as your current firmware in the unit. If the versions are not matching then an incompatibility issues could occur.
5 Integration Menu
If you have everything right but the unit is still not visible, then the only problem can be that the EX Bus port of your receiver is configured to a different protocol.
6 Usage
Always close the integration menu with Close the menu. Otherwise Bank Switching or Real-Time tuning features will be temporarily disabled.
7 Preset for transmitter
The profile has enabled:
  • Flight modes
  • Bank Switching
8 Channel Mapping
Channel Layout:
  1. Throttle
  2. Aileron
  3. Elevator
  4. Pitch
  5. Rudder
  6. Gyro sens.
  7. Bank (if used)
  8. Stabi (if used)
9 Telemetry data
  • S Altitude [m] - Model altitude measured from lift off position.
