HobbyWing Telemetry
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC firmware to a recent, non VBar firmware.
1 Telemetry Cable
We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit. The Red wire must be internally disconnected always!
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
HobbyWing ESC can transmit Current and Consumed Capacity only when there is a load. Without main blades it will show zero value..
5 Supported models
Model |
Battery Voltage |
Battery Current |
Consumed Capacity |
ESC Temperature |
RPM |
Platinum 25A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 40A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 60A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 80A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum 120A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 130A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 130A OPTO V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 160A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 200A OPTO V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
