Intermitente fallo
Revision as of 11:25, 25 May 2022 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
1 La unidad no funciona después de parpadear
In case that your unit is not operating correctly after flashing process, you can use the following guide to make it work again.
La pregunta importante es, ¿por qué fallo?
Las posibilidades son:
  • conexión entre la unidad y el ordenador no es estable (compruebe los cables).
  • Bad USB interface driver in your Operating System.
Si está en Windows, reinstale el software con la opción de instalación del controlador. Entonces se instalará el controlador correcto. Luego reinicie el PC.
Si está en mac, utilice este controlador: OSX 11.0 Big Sur
Otros drivers muy probablemente no funcionarán correctamente - especialmente para el proceso de parpadear!
Requirements for the Recovery process:
  1. Controlador correcto en su sistema operativo.
  2. Status LED of the unit must be pulsating after power up.
2 Cómo reactivar la unidad
  1. Conecte la interfaz USB a su PC y la unidad (SYS port).
  2. Start the software. Select Recovery mode when prompted.
  3. Choose correct COM port in the Connection tab first.
  4. Go to the Update tab and select firmware you want to flash.
  5. Press the Flash button and confirm - software will download firmware from Spirit Server.
  6. Power up the unit (from your BEC or a battery) when you see 0% progress bar. Immediately after power up flashing should start.
  7. In 10 seconds, unit should be operating again without any issue. Your settings are untouched.
