HobbyWing V5 Telemetry/de
Revision as of 11:48, 4 July 2022 by Admin (Talk | contribs) (Created page with "Telemetriekabel")
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
HobbyWing Platinum V5 ESC hat eine Telemetriefunktion im Programmieranschluss integriert. Dies ermöglicht die Telemetrie-Datenübertragung zum Gerät.
1 Telemetriekabel
2 Interfacing
There is no support for Spirit v1 units.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the HobbyWing Platinum V5 option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 150A V5
