Spirit-Link
Revision as of 10:30, 10 November 2022 by Admin (Talk | contribs)
1 Description
Spirit-Link is innovative module to allow wireless access to all Spirit units. It has support for BlueTooth and WiFi standard in the one, small form factor.
Module called Spirit-Link (BT) is preloaded with firmware for BlueTooth and can be used as a classic BlueTooth module. It replaced completely older Spirit BlueTooth modules. Since module can be updated Over The Air it can act as Wifi-Link in the future.
Info.pngBlueTooth firmware is for Android devices only.
2 Wiring
Example: Wiring photo
Wire Meaning
GND Ground powering lead
Info.png TX wire must be always closer to the SYS label. RX wire must be always in the center pin of the SYS port.
Warning.png Do not connect communication cable to the power supply! It can be connected only to the SYS port.
3 Usage
Spirit-Link module can be used with all Android based devices such as Smartphones and Tablets. There is free application available at Google Play:
3.1 Pairing
Before you can start to use Spirit-Link (BT) module you have to pair your device in the BlueTooth system menu. After pairing you will see the device in Spirit Settings for Android and you can connect to the Spirit unit anytime.
Pairing is usually performed only once with any device.
