EthOS
Revision as of 15:55, 10 November 2022 by Admin (Talk | contribs)
Spirit units have full support for FrSky EthOS radio system. You can configure Spirit units directly from radio and also view telemetry values.
1 Setup
Download integration scripts from our web page or this LINK.
Extract downloaded ZIP file and copy whole directory "spirit" to "scripts" to SD Card of your radio. Then (re)power the radio and from then you will see Spirit icon in the Settings menu.
2 Usage
You can start the Spirit integration at any moment from second page of the Configuration menu.
The integration scripts should work with all EthOS radios. With F.Port connection integration will work faster.
Do not forget to save any changes in the settings by clicking Save Settings in the integration menu.
After exiting the integration, please make sure that the unit is not in the Configuration mode - Status LED should be steady On before a flight.
