OMP Telemetry
Revision as of 11:27, 29 November 2023 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎español • ‎italiano • ‎русский
OMP M4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
1 Telemetry Cable
To allow the telemetry data transmission the Telem OMP cable is required. This cable is available in our Eshop.
Warning.png We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit. The Red wire must be disconnected always!
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port (SAT1) in the unit - apply for Spirit 2, Spirit RS, Spirit Pro, Spirit GT, Spirit GTR, Spirit W1.
There is no support for Spirit v1 units.
Servo connector of the Telem OMP cable should be connected to the ESC - programming port.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the OMP M4 option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
OMP M4
