SpiritW1 Binding
Revision as of 11:14, 9 January 2024 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎français • ‎italiano
1 Binding Procedure
In order to Bind Spirit W1 with your Wave radio use supplied Bind plug.
  1. Insert Bind plug at the SYS port and connect Power supply to the Spirit W1 unit. You can connect BEC or 1-3S Battery at the THR, AUX ports.
  2. Spirit W1 unit will start to blink with the Status LED periodically.
  3. Then power up your Wave radio.
  4. Radio will automatically bind to the receiver when using new Model profile. You can also Bind anytime manually as described in the section above.
  5. After successfull binding Spirit unit will stop blinking and will initialize. Then you can remove the Bind plug.
1.1 Manual Binding
You can Bind manually by going to the Model/Receiver menu. Press the Bind button after powering up Spirit W1 with a Bind plug.
