Spirit Wave ESC Telemetry
Revision as of 11:22, 27 February 2025 by Admin (Talk | contribs) (Created page with "<translate> ESC Telemetry is feature that allows you to display and log data from your Electronic Speed Controller (ESC) directly at the Wave Radio. The ESC Telemetry is media...")
ESC Telemetry is feature that allows you to display and log data from your Electronic Speed Controller (ESC) directly at the Wave Radio. The ESC Telemetry is mediated through the Spirit unit as these are able to read the data and communicate with both receiver and ESC at the same time.
Spirit Wave has support for all common Telemetry capable ESC protocols.
1 List of supported ESCs
- Castle Creations Phoenix & Talon
- HobbyWing Platinum V4
- HobbyWing Platinum V5
- Scorpion Tribunus
- Kontronik KOSMIK & JIVE PRO
- Kontronik JIVE
- YGE LVT/HVT
- Kontronik TelMe Telemetry
- Graupner Telemetry
- XDFly, ZTW and OMP Telemetry
- Spektrum Avian Telemetry
2 Interfacing
3 Telemetry data
Available Telemetry variables are dependent on used ESC. Please refer to the section Supported models in particular page of the ESC.
- Battery Voltage [V]
- Battery Current [A]
- BEC Voltage [V] - provided by ESC Telemetry or Receiver.
- BEC Current [A] - provided by ESC Telemetry.
- Consumed Capacity [mAh] - Battery Capacity consumed from the initialization point.
- ESC Temperature [°C] - Usually temperature of the FET transistors.
