Spirit Wave ESC Telemetry
Revision as of 13:23, 27 February 2025 by Admin (Talk | contribs)
ESC Telemetry is feature that allows you to display and log data from your Electronic Speed Controller (ESC) directly at the Wave Radio. The ESC Telemetry is mediated through the Spirit unit as these are able to read the data and communicate with both receiver and ESC at the same time.
Spirit Wave has support for all common Telemetry capable ESC protocols.
1 List of supported ESCs
2 Interfacing
3 Telemetry data
Available Telemetry variables are dependent on used ESC. Please refer to the section Supported models in particular page of the ESC.
  • Battery Voltage [V]
  • Battery Current [A]
  • BEC Current [A] - provided by ESC Telemetry.
