ESC telemetry
Revision as of 13:23, 27 February 2025 by Admin (Talk | contribs)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
Info.png These radios support full integration/telemetry as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
  • Battery Voltage [V]
  • Battery Current [A]
  • Head Speed [RPM] - provided by RPM sensor or ESC. (also with ESC Telemetry disabled)
  • Altitude [%] - provided by Spirit GT, GTR, W1, GeoLink units. (also with ESC Telemetry disabled)
