Sicherheitshinweise
Revision as of 15:46, 30 October 2025 by ErnieDembowsky (Talk | contribs) (Created page with "R/C-Modelle wie Hubschrauber, Flugzeuge oder Drohnen sind keine Spielzeuge! Es ist erforderlich, alle Herstelleranweisungen des Modells zu prüfen, die örtlichen Gesetze einz...")
čeština • ‎Deutsch • ‎English • ‎français • ‎italiano
Sicherheitshinweise
R/C-Modelle wie Hubschrauber, Flugzeuge oder Drohnen sind keine Spielzeuge! Es ist erforderlich, alle Herstelleranweisungen des Modells zu prüfen, die örtlichen Gesetze einzuhalten und Vorflugkontrollen des Modells durchzuführen, um mögliche mechanische oder elektrische Probleme und Defekte umgehend zu erkennen und zu beheben.
Rotor blades and propellers rotate at high speed and can lead to serious injury to persons and property if not respected.
If you encounter any problems, contact your dealer or other experienced modelers.
Pay particular attention to your own safety and the safety of others. Never fly amongst or over people, animals, or on private property without prior authorization from the property owner. Fly only in safe places where no additional damage is possible to other objects, because the model can suddenly become unmanageable for various reasons, such as failure of electronics, mechanical failure, pilot error or radio interference.
Do not try to fly damaged models or perform repairs using damaged parts; always replace damaged parts with new ones. Never fly a model which exhibits abnormal behavior or excess vibrations, this may cause unwanted flight characteristics or in-flight failures. Find the source of the vibrations and fix the problem.
Info.png User takes full responsibility for any damage or injury caused while flying an R/C model equipped with one of our devices. The manufacturer can neither guarantee nor control the conditions in which the unit is being used.
