Jeti Integration
Revision as of 10:16, 23 July 2026 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
1 Voraussetzungen
  • Jeti Duplex transmitter: DC/DS 12, 14, 16 or 24
  • Jeti Duplex-Empfänger mit einem freien EX-Port
  • Jeti Integration cable available in our stores (not for Spirit 3, GT).
  • Konfigurationsdatei für den Sender.
2 Verkabelung
PHOTO: Jeti Integration Cable
2.2 Spirit 3, Spirit GT
Spirit 3 and Spirit GT require only stright cable supplied with the unit itself. Cable must be connected at the RUD port with no modification.
2.3 Spirit RS, Spirit GTR
These units have integrated JETI receiver. It is not needed to do any of these wiring or settings.
2.4 microSpirit
These units require special version of the JETI integration cable designed for microSpirit. It is available in the Spirit System eshop.
2.5 JETI receiver side
At the receiver side the servo connector must be connected to the EX Bus port.
  • For new REX receivers the port is called E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always called EXT.
Info.png Wenn Sie EX-Empfänger mit angeschlossenem Telemetriesensor zum EXT-Anschluss verwenden, haben Sie in diesem Fall zwei Möglichkeiten:
  • Benutzen Sie eine UDI-Verbindung (SRXL / SUMD-Empfängertyp)- In diesem Fall verlieren Sie die Jeti-Integration.
  • Kaufen Sie einen REX-Receiver, wo Sie Telemetriesensoren und die Jeti-Integration zusammen nutzen können.
3 Sender Vorbereitung
Laden Sie jetzt die Konfigurationsdatei from our Spirit web page by clicking at the JETI icon at the bottom of the web page, which has ZIP extension. The file archive must be extracted first (by Right click). You will obtain SPIRIT-3-X folder. Content of this folder must be copied to the Devices directory at the SD-Card of your transmitter. Without this you will see an error message when the Spirit device is opened.
This mean Devices directory will contain SPIRIT.bin file and SPIRIT directory with images inside.
4 Spirit Einstellungen
Jetzt sind Sie bereit, das Gerät einzuschalten. Wenn Ihre Stromversorgung noch nicht angeschlossen ist, empfehlen wir den Anschluss an die Buchsen AUX1, AUX2 und / oder CH0. Bevor Sie die Jeti-Integration und die EX-Bus-Verbindung nutzen können, ist es wichtig, den EX-Bus-Empfängertyp in der Registerkarte General in der Software einzustellen. Bitte starten Sie die Spirit-Einstellungen und ändern Sie den Empfängertyp, wie auf dem Foto angezeigt. Speichern Sie dann die Einstellungen (z. B. durch "CTRL + S") oder in der Registerkarte Backup/Unit-Save und starten das Gerät neu.
5 Integration Menu
Dann wählen Sie das Menü "Modellauswahl" (Model) mit dem Drehknopf aus.
Und dann das Menü "Geräteübersicht" (Device Explorer) aufrufen.
Dort, wenn die Verkabelung und Empfängertyp korrekt ist, werden Sie den Spirit Eintrag sehen.
If you have everything right but the unit is still not visible, then the only problem can be that the EX Bus port of your receiver is configured to a different protocol.
6 Verwendung
Wann immer Sie einen Parameter konfigurieren möchten, gehen Sie zur Modellauswahl / Geräteübersicht / Spirit. Dort ist die Menü-Anordnung fast identisch mit der PC-Software, um eine einfache Navigation zu haben.
Warning.png Führen Sie die Konfiguration niemals während des Fluges durch!
Bei Verwendung der Bankumschaltung oder der Echtzeit-Tuning-Funktionen wird das Menü die volle Kontrolle übernehmen. Das Gerät reagiert dann nicht auf Schalterwechsel. Für die Bankumschaltung gibt es ein Menü "Bank Switching", mit dem Sie die Bänke manuell wechseln können.
Schließen Sie immer das Integrationsmenü mit Close the menu. Andernfalls wird die Bankumschaltung oder Real-Time tuning vorübergehend deaktiviert.
Vergessen Sie nicht Save Settings zu verwenden, wenn Sie eine Änderung dauerhaft speichern möchten.
7 Voreinstellung für Sender
Sie können unser vorkonfiguriertes Profil für den Sender verwenden, wo alles konfiguriert sein sollte, um fliegen zu können.
Das Profil hat aktiviert:
  • Flug Modi
  • Bankumschaltung
  • Rettungs-/Stabilisierungs Modi (aktiviert durch einen separaten Kanal)
Sie können es hier herunterladen (optimiert für Jeti DS-14). Dann entpacken Sie die Datei und speichern die JSN-Datei auf Ihren Sender (SDCard) in das Modell Verzeichnis.
In deinem Sender gibt es ein neues Profil namens Spirit FBL, das du auswählen kannst.
Genießen Sie die Integration!
8 Kanalzuordnung
Falls Ihre Kanäle nicht übereinstimmen, empfehlen wir, die Standard-Kanalzuordnung im Gerät so zu lassen und in Ihrem Sender zu ändern.
Sie können dies im Menü Modell - Servozuordnung tun.
Kanal Layout:
  1. Throttle (Gas)
  2. Aileron (Querruder)
  3. Elevator (Höhenruder)
  4. Pitch (Kollektiv)
  5. Rudder (Seitenruder)
  6. Gyro sens. (Heckkreisel-Empfindlichkeit)
  7. Bank (if used)
  8. Stabi (if used)
9 Telemetrie Daten
Um die Telemetriedaten anzuzeigen, müssen Sie zuerst nach neuen Sensoren scannen. Gehen Sie zu Menü - Stopuhren/Sensoren - Sensoren/Aufzeichnung und drücken Sie dann AUTO Taste (F3). Das Scannen dauert einige Sekunden, bis alle Telemetrievariablen angezeigt werden.
  • S Vibes [%] - Vibrationlevel von allen Achsen (0 - 10% ist normal)
  • S RPM [Head RPM] - RPM bereitgestellt von RPM sensor.
  • S Voltage [V] - ESC Telemetry | Spannung Hauptakku
  • S Current [A] - ESC Telemetry | Strom Hauptakku
  • S Capacity [mAh] - ESC Telemetry | verbraucht Kapazität Hauptakku
  • S Temp [°C] - ESC Telemetry | FET Temperatur
  • S Altitude [m] - Model altitude measured from lift off position.
  • S Speed [km/h] - Flight Speed of the model measured by Spirit GeoLink module.
Sobald das Scannen beendet ist, können Sie diese Variablen auf den Hauptbildschirm hinzufügen. Gehen Sie zu Menü - Stoppuhren/Sensoren - Telemetrieanzeige und drücken Sie die + Taste (F3). Fügen Sie alle Telemetriedaten hinzu, die Sie anzeigen möchten.
