Wifi-Link
Revision as of 10:39, 9 January 2017 by Spiritdm (Talk | contribs)
Wifi-Link manual
1 FEATURES
Power supply: 3.3V - 15V
Weight: 7g
Dimension: 21x32x5.5mm
Operating range: up to 50 meters
Modes: AP, AP+Client, Client
Standard: 802.11b/g/n
Encryption: Open, WEP, WPA, WPA2
Configuration: Web Interface
Power consumption: 80 – 350mA
Supported devices:
  • Android (available on the Google Play)
  • All smartphones, tablets, smart TV with Web Browser
  • PC
  • Mac
Support for Firmware Updates.
Web based Spirit Settings app in the module!
2 CONNECTION
Wire Meaning
GND Ground powering lead
TX wire must be always closer to the SYS label RX wire must be always in the center pin of the SYS port
3 CONFIGURATION
Default SSID (Wifi site name): Spirit Wifi-Link. The module is by default in the Acess Point mode. You can connect to the AP directly in a normal way.
After connection, your device will get IP address automaticaly.
  1. Open your web browser.
Usually any modern web browser with JavaScript support can be used.
style="text-align:center;" ↑Up↑
