Wifi-Link
Revision as of 16:02, 10 January 2017 by Admin (Talk | contribs)
Wifi-Link
manual
1 FEATURES
Power supply: 3.3V - 15V
Weight: 7g
Dimension: 21x32x5.5mm
Operating range: up to 50 meters
Modes: AP, AP+Client, Client
Standard: 802.11b/g/n
Encryption: Open, WEP, WPA, WPA2
Configuration: Web Interface
Power consumption: 80 – 350mA
Supported devices:
  • Android (available on the Google Play)
  • All smartphones, tablets, smart TV with Web Browser
  • PC
  • Mac
Support for Firmware Updates.
Web based Spirit Settings app in the module!
2 CONNECTION
Wiring photo
Wire Meaning
GND Ground powering lead
TX wire must be always closer to the SYS label. RX wire must be always in the center pin of the SYS port. VCC and GND can be connected to any port, except ELE/PIT/AIL and SYS. It can be connected to a receiver port too. If powered from a separate battery, GND must be connected with the unit's power source.
3 CONFIGURATION
    The module is by default in the Acess Point mode.
    You can connect to the AP directly in a normal way.
    After connection, your device will get IP address automaticaly.
  2. Open your web browser.
    Usually any modern web browser with JavaScript support can be used.
    By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
For beginners, we recommend default settings.
Module is able to connect to an existing WiFi station (e.g. your home site). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to your WiFi site, even via an ethernet cable.
If you are connected to an existing WiFi station, the module will receive second IP address. You can find such IP address in the configuration interface.
You can connect to the interface from the second IP address when accessing from your network. You can also access the internet or module at the same time.
4 USAGE
Native Android app
Native PC & Mac app
