Jeti Integrace
Revision as of 14:26, 12 January 2017 by Spiritdm (Talk | contribs) (Created page with "Soupravu Jeti Duplex DS/DS 14, 16 nebo 24")
Od verze 1.1.0 je k dispozici Jeti integraci! To znamená, že je možné jednotku plně konfigurovat přímo z Jeti vysílače bez použití počítače.
1 Požadavky
  • Soupravu Jeti Duplex DS/DS 14, 16 nebo 24
  • Jeti Duplex receiver with a free EX port.
  • Jeti Integration cable available in our stores.
  • Configuration file for the transmitter.
2 Wiring
The Jeti cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • For new REX receivers the port label is EX1 or EX2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
  • To buy a REX receiver where you can use a telemetry sensors and the Jeti integration together.
3 Transmitter preparation
Now download the Configuration file, which has BIN extension. The file name is "Spirit.bin". This file should be copied to the "Devices" directory on the SD-Card of your transmitter. Without it you will see the error message when the Spirit device is opened.
You can copy it by connecting the micro USB cable to the transmitter similarly as to an USB flash drive. When cable is attached to the transmitter you have to confirm the USB connection. Then simply drag and drop it to the Devices directory as you are used to.
It is very important to use the same version of the BIN file as your current firmware in the unit. If the versions are not matching then an incompatibility issues could occur.
5 Integration Menu
When unit is initialized you are able to enter the Jeti Integration menu. Press the MENU button on the transmitter.
5.1 Stil can't see the Spirit?
In this case, enter the configuration menu of your receiver in the Device Explorer - the entry has name of your receiver. Change the Serial Link to the EX Bus. In case of the REX receivers you can assign EX1 or EX2 port..
6 Usage
