Hott Integracion
Revision as of 21:23, 11 March 2017 by Gotas (Talk | contribs) (Created page with "Utilice el '' 'cable de integración hott' '' disponible en nuestro eshop. Conéctelo de acuerdo con los siguientes pasos: #end con conector servo negro debe estar conectado a...")
Desde la versión 2.3 las unidades spirit soportan la plena integración con los transmisores hott de graupner. Esto significa que puede configurar las unidades de spirit completamente de su radio sin necesidad de una computadora.
La integración puede funcionar con todos los receptores y radios hott excepto mz-4 y mz-8.
1 cableado
To allow the integration you have to connect additional cable to your current setup. This cable will connect the Telemetry port of the receiver with the SYS port of the unit. So there should be two connections between unit and receiver for:
  • Channel transmission (PWM, PPM or SUMD)
  • Telemetry and Integration data
Utilice el 'cable de integración hott' disponible en nuestro eshop. Conéctelo de acuerdo con los siguientes pasos: #end con conector servo negro debe estar conectado al receptor en el puerto de telemetría marcado con la etiqueta 't' . #end con el conector rojo del servo debe ser conectado al puerto del sistema.
Warning.png It is very important to pay attention during the connection!
If connected wrongly, it will damage the unit permanently. The cable end where red wire is in the middle pin must be always connected to the unit. Never use other cables for this connection!
Info.png Servo connector in the Graupner Hott receivers is connected so that the signal wire is at the bottom.
2 Receiver configuration
In your transmitter, go to the Function (F)/Telemetry/Setting & Data View where you have to change option SENSOR at CHx to YES.
3 Entering the menu
Graupner MZ-18 - Integration menu
Graupner MZ-18 - General page
4 Sensor Emulation
Available types are:
  • GAM - General Air Module
  • EAM - Electric Air Module
5 Telemetry data
With the Spirit firmware 2.3.0 you are able to view:
  • Current RPM from the Governor.
  • Vibrations of the model (Reported as Fuel in the GAM)
6 Usage
Info.png Do not forget to click the Save Settings when you want to save the changes permanently.
Info.png Before flying press the ESC button to exit the integration menu.
