Scorpion Telemetry
Scorpion Tribunus ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit.
[hide]1 Telemetry Cable
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Scorpion Tribunus option.
4 Displaying telemetry data
