Funkce GeoLinku
Revision as of 14:12, 30 July 2018 by Admin (Talk | contribs) (Created page with "Montáž")
GeoLink offer variety of features that can be enabled on demand while flying. Some can be also combined to offer the experience you would like.
1 TTFF Accelerator
This feature allow to significantly reduce period in which GeoLink module can fix to a navigation satellites. With some devices it takes even few minutes. With GeoLink this period can be reduced to just 6 seconds while no battery backup is needed.
1.1 How it works
When module is powered up for the first time at a given day it is trying to find a satellites. It will do so in a normal way (without any time reduction). With GeoLink this should be between 20 - 35 seconds normally (depending on conditions).
Right after the flight and next power up this period is reduced significantly. When powering up within few minutes to hours you can always notice the time required for Fix is shortened.
1.2 How can it help me?
2 Logging
2.1 Logging specification
  • Up to 1.5 hour
  • Up to 63 logged flights
  • Recording period: 1 second
2.2 What is being logged?
  • Position on Earth: Latitude and Longitude
  • Altitude: relative altitude from starting point
  • Speed: flying speed of the model
  • Heading: direction in which model is flying
  • Date and time
2.3 Log viewer
2.4 Log backup and sharing
3 Return To Home
  • in the Spirit Settings by choosing the best spot at the map
  • by transmitter command being at the place considered as a new Home.
3.1 Description
3.2 With Altitude Hold
4 Position Hold
4.1 Description
4.2 With Altitude Hold
5 Geo-fence
5.1 Description
5.2 With Altitude Hold
6 Altitude Hold
6.1 Description
7 Altitude Limit
7.1 Description
If engaged the model will fly without any change in behavior. But as soon as the model will fly under configured altitude the Rescue mode is activated automatically until the model ascend above this level.
