Bezpečnost
Revision as of 15:00, 15 September 2016 by Admin (Talk | contribs) (Created page with "R/C modely jako např. helikoptéry nejsou hračky, proto je nezbytné zachovávat všechny pokyny výrobce daného modelu, dodržovat místní zákony, preventivně kontrolov...")
R/C modely jako např. helikoptéry nejsou hračky, proto je nezbytné zachovávat všechny pokyny výrobce daného modelu, dodržovat místní zákony, preventivně kontrolovat model a všechny závady ihned odstranit.
Rotor blades and propellers rotate at high speed and can lead to serious injury to persons and property if not respected.
If you encounter any problems, contact your dealer or other experienced modelers.
Pay particular attention to your own safety and the safety of others. Never fly amongst or over people, animals, or on private property without prior authorization from the property owner. Fly only in safe places where no additional damage is possible to other objects, because the model can suddenly become unmanageable for various reasons, such as failure of electronics, mechanical failure, pilot error or radio interference.
Do not try to fly damaged models or perform repairs using damaged parts; always replace damaged parts with new ones. Never fly a model which exhibits excess vibrations, this may cause unwanted flight characteristics or in-flight failures. Find the source of the vibrations and fix the problem.
Spirit is not an autopilot, it is necessary to have knowledge of flying R/C models. The system is only designed to improve flight performance. We recommend using R/C simulators designed for training before the first flight.
The user takes full responsibility for any damage or injury caused while flying an R/C model equipped with one of our devices. The manufacturer can neither guarantee nor control the conditions in which the unit is being used.
