HoTT Telemetry
This page is a translated version of the page HoTT Telemetry and the translation is 100% complete.
čeština • ‎Deutsch • ‎English • ‎español • ‎français • ‎italiano • ‎русский
Graupner HoTT ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC firmware to a more recent.
It is important to flash firmware with Sensor Emulation called EAM - Electric Air Module.
1 Telemetry Cable
2 Interfacing
Servo connector of the Telem UNI cable should be connected to the ESC - telemetry/programming port.
350px
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Graupner HoTT option.
4 Displaying telemetry data
Warning.png Please update your ESC firmware to the most recent firmware. It is important to flash firmware with Sensor Emulation called EAM - Electric Air Module.
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Graupner Cool Control +T 160HV ✔ ✔ ✔ ✔ ✔
Other unlisted models that are telemetry enabled with a proper firmware should work too.
