Configuration
Revision as of 08:41, 16 September 2016 by Admin (Talk | contribs) (Created page with "Mixování ve vysílači musí být vypnuto. Je nutno nastavit typ mixování H1.")
1 CONNECTION TO PC
2 PROPOJENÍ S JEDNOTKOU
POZOR
UPOZORNĚNÍ
PROBLÉMY VE WINDOWS
5 POUŽITÍ SOFTWARE
5.1 ZÁLOŽKA SPOJENÍ
5.2 ZÁLOŽKA OBECNÉ
UPOZORNĚNÍ
Pozice
Deska cykliky
PWM – standard receiver.
PPM – single line connection.
Flight style
Channels
  • N – Normal (Rate)
  • HL – Head Lock
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
