Configuration
Revision as of 09:50, 16 September 2016 by Admin (Talk | contribs)
1 CONNECTION TO PC
2 PROPOJENÍ S JEDNOTKOU
4 CONFIGURATION SOFTWARE
UPOZORNĚNÍ
PROBLÉMY VE WINDOWS
5 SOFTWARE USAGE
5.1 CONNECTION TAB
5.2 ZÁLOŽKA OBECNÉ
UPOZORNĚNÍ
Pozice
Deska cykliky
Přijímač
PWM – standard receiver.
Spektrum DSM2/DSMX – DSM2/DSMX – satelit s podporou DSM2/DSMX.
Letový projev
Channels
Realtime ladění
UPOZORNĚNÍ
5.3 ZÁLOŽKA DIAGNOSTIKA
UPOZORNĚNÍ
  • N – Normal (Rate)
  • HL – Head Lock
  • HF – Head Lock s aktivní funkcí cykliky, viz parametr Funkce.
FREKVENČNÍ ANALYZÁTOR
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
